Sl Hood Repair
dewimerc
Gwynedd
SL350 - 2013
There is a very small rip in one of the plastic rear quarter panels of my Mercedes SL hood.
Does anyone know if it’s possible to replace these plastic panels or will it be necessary to replace the hood?
The windows can be replaced and quite a few firms out there that do it, you do need to get the original type of vinyl if possible
I will see what I can find,,where are you in the UK
D
dewimerc
Gwynedd
SL350 - 2013
I'm based in North Wales but am in Manchester quite often.
myredsl
Weybridge,Surrey
1988 300sl, 1991 300ce, 1991 190e
Hood repair
Hi,I too would like any info on plastic quarter light repair as my 129 also has a tiny split right where the hood folds when stowed.
mglb
w yorks
i have just had my rear windows replaced by pickerings in bradford excellent job £294 mark
Explorer 1
SL soft top problem.
Hope you don't mind me adding another roof problem to this thread - my problem is that the outer stitching on the two track stitching on my 129 soft top has come loose for about 5 inches. Roof is still watertight as inner track stitching is fine. Can the stitching be repaired without removing whole rear section, or does this need to be removed and re-stitched on a bench - and begs question if off, might as well replace plastic windows. been quoted £299 for all 3 panels to be replaced. if you need contact, let me know.
cheers
myredsl
Weybridge,Surrey
roof repair info
Hi,I`d really appreciate whatever roof info you have.
Many thanks
cheers
myredsl
Weybridge,Surrey
Hi Mark,do you have contact details for Pickerings,Bradford?
Nick
mglb
w yorks
hi myredsl sorry i did not get back sooner but i have been away A.S PICKERINGS coach trimmers and upholsterers springfield place manningham lane bradford tel bradford 724000 did my windows ,they did an excellent job and were nice people to deal with i hope this is of some use MARK
Pipemaster
East Midlands
SL350 R230 / 2006 / 3500
Folding cracks the plastic below 10 degrees
After talking with an MB Mechanic after my previosu Sl's ('95) rear window split across the fold - MB unofficial take on it is that using the soft top below 10 degrees is likely to casue the plastic to crack. Later rooves had greater resilience. This info does not appear in any MB literature on the SL though....
