SL (R230) Central Locking Pump
l5foye
Can anyone tell me the best way to waterproof a central locking pump please? I know replacing the roof seals is the cure but cost puts that on the long finger. I have been thinking of plasti dip-has anyone tried this product?
malcolm E53 AMG
Unfortunately the accredited forum expert on R230 folding roof leaks was banned a couple of weeks ago. Do a search on R230 roof leaks and water proofing the central locking pump there is a lot of info on the forum.
If Malcolm (aka Television) decides to return to the forum you should be able to get detailed instructions from him.
DSB SL AMG
Cheshire
300SL (R129 1992 Pre-Facelift), Volvo V70 D5 SE Auto
hmm the link above shows Malcs R230 seal fix...
STEc74
St Helens,Merseyside
My car SL 350 05,sons car CLK320,other cars BMW 318IS ,95, 1964 Chev Corvair Monza restoring.
I am interested to know how you intend to plastic dip the pump,personaly i have never used this product but would be interesting to see if it works,i took out my pump for inspection after blowing a fuse,no damp in pump but sponge was wet and water in the boot well caused by blocked drain holes in the top boot seals,as said television was the master of this problem,he helped me whith my problem theres a good discusion on the forum about the psi pump and keeping it dry.
Clkrichard
Chichester
CLK 320 Cabriolet 2004, R 230 SL 500 2005, new A class AMG Sport.
I took out the sodden foam and after completely drying it I wrapped it in cling film. It is only a protective buffer against things above it in the boot. I then thoroughly sprayed pumps, wiring, everything in sight with Holts Ignition sealer spray. This puts a non conductive waterproof plastic seal over everything.
If itbworked on my Mini distributors in the 60s exposed to the blast of the weather at the front of the engine then it should protect PSE pumps and associated wiring and electrics.
Dont forget to check that the bung/ valve in the bottom of the boot is clear
drmw
Yorkshire
www.autonomed.co.uk
see post 45 here - http://forums.mercedesclub.org.uk/showthread.php?t=87222&highlight=bubblewrap&page=5
Plaastidip won't do any harm, but won't seal it either. It has a myriad of air lines plus wiring going into it and you couldn't seal around them
