Teridor
New Registration
- Dec 28, 2012
- Location
- Kent UK
- Website
- www.a1chauffeurhire.com
- Mercedes Benz 2003 E 270 cdi /SL350 2005 r230 /2003 C class 270cdi Est.
I have been on all the forums having bought a 2005 SL350 R230 with a hardtop rattle .Love the car to bits but the rattle just rear of the headrests drove me mad. Went on all the forums they all talk about this rattle [and there are lots of them even in the USA] and a silicon oil you can buy a 3m Silicon dry oil that you spread on the seals ..But I kept thinking this is a cracking / knocking noise not a rubber grind or rubber unsticking noise ..Its got to be an adjustment or something has worn , I noticed if I pushed down on the roof joint where it meets the rear side pillars it made a rubbing noise telling me that area must be loose and inside thats where the knocking or cracking noise came from . On looking at the pivot bolts I can see cork type washers as though someone else has had a go at it .. Well I kept thinking and when looking at the hinge linkage I could see two sets of bump stops one set on adjustable bolt like you would have under the bonnet to adjust the two front sides of the bonnet . So I marked an upright mark on the rubber bump-stop and with a 10 mm spanner undid the bolt and screwed it out two turns tightened up and then drove it round the block and I thought MMmmm seems a bit quieter but not sure . Got back up with the hardtop to a central position keeping the engine running and adjusted it out two more turns. Went for another drive round our bumpy side roads and guess what all cracking noises gone my smile went from ear to ear as I seen on these forums owners spending fortunes with dealers and not getting it sorted out.Some dealers dont even want to get involved if they have not done one before . So folks give this a try it may be all your problem is . As it was mine... hope Ive solved a lot of SL owners annoying hardtop rattle .Im going to try and put some pics on here with circles around the areas Im talking about .Where you see the red cross thats the one I adjusted .The other I did not touch as it did not look like it was adjustable so just try with the one that takes a spanner marked with a red cross ....GOOD LUCK Terry
