sl r230 suspension sitting high
8678aggy
Newcastle
SL 350 R230 2007
hello,the back end of my sl sits very high and i cannot get it to lower,i do not see any sensors on the shockers so i was wondering if it was possible to adjust manually or if you can lower using star how do you do it,i have a chinese star. .mike
Its sitting high becuase there is an issue with it, what codes are read from ABC module?
There are 2 sensors on the rear suspension and 2 front.
It can be leveled on STAR, the correct height is 70cm from the top of all 4 wheel arches to ground
You have a fault with the rear valve body, We are seeing a few of these now, most times a strip out and full clean of the body and full oil flush with a new filter cures it!......
8678aggy
Newcastle
SL 350 R230 2007
the car was pulled from the back when recovered from a watery grave and it affected the ride height,i cannot see any of the suspension rods bent,do you think this might be the cause of my rear end grinding noise
8678aggy
Newcastle
SL 350 R230 2007
i will have to have a look ,no faults on star what do i need to look for,regards mike
toby1
West Berkshire
Post 4 seemed unambiguous to me
You can go into STAR and set the ride height if it will, but it could have a broken link or the valve damaged as Colin said
8678aggy
Newcastle
SL 350 R230 2007
R230 SUSPENSION
HELLO, I FORGOT TO MENTION THE CAR DOES NOT HAVE ABC SO THE RIDE HEIGHT CANNOT BE ALTERED ON STAR,I BELIEVE THE ACT OF PULLING THE CAR FROM THE REAR HAS CAUSED THE SUSP.TO RISE ,ANY SUGGESTIONS ,REGARDS MIKE
Thats a pretty big thing! The wrong springs have been fitted at some point possibly.
Odd this one, the height should be 70cm from the top of all 4 wheels arches to the ground
8678aggy
Newcastle
SL 350 R230 2007
rear suspension sitting high
hello,still no progress on the height issue ,still thinking that the rear end has been damaged when the car was recovered,does anyone know of a suspension specialist in the north east,regards mike
Have you tried the specialist finder, I do not know any where you are :(
Only the springs affect the height, you have 30 and 40
m.mycat
8678aggy
Newcastle
SL 350 R230 2007
hello,the car lifts up when reversing ,as if the handbrake was applied but obviously it is not,it lowers when moving forward but it still does not run at correct height at the rear ,the front axle is ok.regards mike
That sounds pretty bad, are you near wheels in motion? They are very good for anything suspension related.
Sent from a mobile device
It is behaving as though its got ABC
Clkrichard
Chichester
CLK 320 Cabriolet 2004, R 230 SL 500 2005, new A class AMG Sport.
If it hasnt got ABC then surely there is nothing for STAR to check ?
I think something had broken, maybe subframe bushes etc. Need somebody underneath it :)
Clkrichard
Chichester
Unsurprising if it was dragged backwards from a watery grave !
