Yes i have ,what do i have to do??
Also when the engine reaches running temp it devolps a misfire and will not start until it as cooled down i have changed both temp sensors any ideas ??
Thanks Graham
If the windows won't drop the roof will not move. Have you checked the fuses in the boot? I have had a blown fuse stop the windows from operating on mine and then the roof won't work either. The fuses can also corrode and loose contact as a result. The recommendation in the manual is not to move the roof if the temperature is below +10C. Maybe Kent is a lot warmer than Worcestershire but I wouldn't be moving my roof in this weather!
Thanks Richard...ah but you have a sunnier disposition up there !
The windows drop ok with from the window switches and go down with the one touch.I guess i will wait till the spring. I have had dozens of W140s but this is my first SL. I have to say thats its probably the most understated/underated and beautifully engineered car in the world. I love the coupes but this,,,,,.....excuse i have to lie down for a bit.
PS i have no power to the seat switches, intermittent wipe or indicators.
The instrument cluster blinks the lights for a few secs then goes out but the engine runs very well. Maybe spiked the cluster resistor?
I wish i felt more confident to contribute more to this forum but you guys keep a lot of these cars on the road.!
Sorry I can't help any further, that's the limit of my technical expertise with R129 roof mechanisms. It says an awful lot about the original quality of the car that after 5 years and 50,000 miles I have had so little need to learn more about how it all works. The only major expenditure in that time has been a a new ignition switch/steering lock assembly and having the roof recovered by KHM in Germany as the original was looking shabby although still weatherproof..
GAD was founded in 2009 where we developed bespoke ECU Remapping software for motorsport clients, moving forward, we have extended to road vehicles for both performance and economy, contact GAD Tuninghttp://www.GADTuning.co.ukto discuss your requirements.
