I have bought a set of alloy wheels off a SL r230 and would like to fit them to my SL r129. Can anyone suggest the correct type of wheel bolt and where I can purchase them from?
Try getting one of the wheel bolts from the 230 and check it against your own bolts, if it is the same, use your own if not the best place to get wheel studs is from the MB dealer
I think you'll find that the 129 bolts are M12 and the 230 bolts M14. Doesn't that make a difference when fitting the wheels due to the different sized holes?
