They are, you can get tools (I have some ) to pull clusters out. Having said that it is really easy to crack the lens when using the tools. It requires a contortionist but if you can get behind and push it out then it’s a much better method.Cluster will need to be removed. Not sure how it comes out but normally MBs are a push fit
Binnacle looks to have been removed.Perhaps I have missed something, but in the photos in post#1 above, has something already been removed ? Looks like the edges of the Perspex are exposed, which they shouldn't be.
There are some instructions here on how to replace the lcd displays. You don't need to go that far, but the early pictures show the bit you want to swap being removed...
https://mbworld.org/forums/attachme...nt-panel-lcd-diy-r230-lcd-replacement-diy.pdf
