Buy a test stick from MB around £36 over here,,or use a length of curtain wire, where when inserted in the tube after removing the seal on the cap, it should be around 5.6cm up the wire with the engine at 80C
Tks Malcolm
I will try the curtain wire method, my biggest problem is in finding the cap !
Dumb I know, is it the black plastic one on top of the bell housing ? which seems to be quite difficult to remove. not tried to much prising yet.
AMF Automotive - We are an independent Mercedes-Benz and AMG specialist located in Paddock Wood, Kent, with full Mercedes Diagnostic equipment. We offer a full
portfolio of tuning options for AMGs and can cater for all your Mercedes needs. Tel: 0203 384 4644www.amfmercedes.com/
