Ray Wiliams
- Thread Starter
- Thread starter
- #21
is the r129 engine in a sl320 the best engineHello and welcome
R129 SL500 Silver Arrow
R129 is the chassisis the r129 engine in a sl320 the best engine
I must admit when we picked up R129 500SL i was shocked to feel how quick the thing moves and how quicknfor its age it can moves between gears! 326bhp i believe in our 92 SL!I want a SL between 1978 and 1993 which is the best model and why/
Is the body work on the sl320 AND 500 THAT MUCH DIFFERENT/The M113’s where fitted from 1998 so don’t be fooled into thinking you have a M119 engine. There are obvious visible differences, the M113 has two spark plugs per cylinder for one,
Where can you go to get this wealth of knowledge and selection personal opinions eh.
All you have to do now is decide which you prefer then find one. I would take a few out for test drives but work you way up the engine sizes or stop when you feel happy and go no further.
If you drive a 500 I think you will want one.
Again, once you have chosen a model you can ask on here for more info, what to look for etc.
No. The bodywork is the same. All r107 (pre 1989) look the same. All r129 (1989 to 2001) are the same and available as both 320 and 500. All r230 (2002 on) are the same and available as 320 and 500.Is the body work on the sl320 AND 500 THAT MUCH DIFFERENT/
Cheers LostKewi i have been looking at a Jersey 320L 1993 is there anything i have to look out forNo. The bodywork is the same. All r107 (pre 1989) look the same. All r129 (1989 to 2001) are the same and available as both 320 and 500. All r230 (2002 on) are the same and available as 320 and 500.
Within each generation there are very small (if any) external differences.
The early r107 can look very different for US markets but that's nothing to do with engines fitted.
I think you're getting confused by the three different generations discussed.
If it is a biodegradable harness what sort of cost and how easy is it to rectify?Ok...
1993 was the year Mercedes introduced the self destructing wiring harness.
The wires were clad in a new biodegradable plastic but unfortunately heat starts the biodegrading process early. To see if it's self destructing look at the wires where they leave temperature senders etc and if the insulation looks to be cracked or wires are exposed it needs doing.
The m104 gas a tendency to blow head gaskets at around 100k miles (probably less for an island car that rarely gets up to any speed).
Aside from those issues normal care and attention to condition is about all you need be concerned about.
The replacement is £700ish for a V8 (no idea for the 6 cylinders) or Sileck in Kent can rebuild them for around half that.If it is a biodegradable harness what sort of cost and how easy is it to rectify?
Mine wasn't till I did it last year.To be fair, if the car is 26 years old, it is likely the harness had been replaced long ago, but worth checking to be sure.
Is there anything you need too look out for from a imported car from Jersey?The replacement is £700ish for a V8 (no idea for the 6 cylinders) or Sileck in Kent can rebuild them for around half that.
Removal and fitting is pretty easy.
Rust from been parked near the seaIs there anything you need too look out for from a imported car from Jersey?
Needs a good blast to clear it out nowhere on Jersey to do more than about 50mphIs there anything you need too look out for from a imported car from Jersey?
I think we need some pics buddyHi
I have bought a 1991 SL500 and want a hardtop storage rack. What's the best one or have anybody got one for sale
