SL500 - knack for removing spark plug leads?
AJBaird
SL500
Hi Everyone
Changing plugs is normally a fairly routine operation, but on the SL, not only do you have 16, but the leads seem very reluctant to come off. I started the job, but found that the leads certainly wanted to put up a fight! I've got some lead 'pliers' that can get a good grip, but when levered against the rocker cover the angle just doesn't work right. On the fourth lead I managed to snap the plug! After struggling to remove the broken plug from the lead I decided I should regroup and come up with a better plan...
I've read that a spanner can be used, but it strikes me that would have the same problem in terms of the angle. Is there a special tool and/or can one be fabricated?
Any help gratefully received.
Cheers
Andrew
star
Reading
Smart + others :)
We use one of these, works a treat.
A
AJBaird
SL500
Thanks for getting back to me. I take it the offset/cranked end means you can apply force in a better direction.
Cheers
Andrew
John Laidlaw
Wirral
Land Rover Discovery 4
Means you can apply force indeed, nice one , I’ve never owned a tappet adjusting spanner !
A
AJBaird
SL500
I've bought an old offset ring spanner from eBay and will get the grinder out...
Thanks for the input.
Cheers
Andrew
