SL55 AMG - Pulse Seats
olimango
Hi
I'm a new member, so please bear with me on this one :)
I collected a 2003 reg'd SL55 over the weekend and wonder whether the pulse seats are working or not. The red light glows when I press it (on both driver and passenger seats) but am not sure whether it's blatenly obvious when the seat is 'in action'. Also there are a number of buttons around the PULSE button, but am not sure whether they are working or not.
When I press them I can hear a 'clicking' as thought something should be happening, but can't tell.
Does anyone think they might be able to help
Look forward to hearing from you.
Olimango
Hello and welcome, I have been where you are today.
First there are mods to the pipes under the seat as either the passenger or drivers seat can kink, blocking the air flow, the easy test is to try the other seat, as both seats do not fail together.
Mine did not work when I bought the car so I asked MB to check on STAR, they said leak on drivers seat,or the PSE pump was u/s, so I took the car home and took the seat apart, thats all of the leather off. made up my own device to blow the seat up and it stayed up all week.
Back to MB and I asked if I could go into the workshop, they let me in and I asked him to see if the car knew that it had comfort seats, he did not want to go there and look, but he did and they were not turned on, that was 2½ years ago and I have enjoyed them ever since, and they are one of the nicest extras on the car
mikestrivens
Stockport
Welcome to the forum. There is a goldmine of info on this site. I've just realised this is my 100th post. Got a fair way to go before I have as many as Malcolm.
100%Bitch
Norfolk 'n' good
215 CL600, 216 Facelift CL500, 172 SLK55, Nissan Cube, R170 SLK230 & an Auto Trail Comanche.
You will know if your massage is working or not as the airbags in the seat will inflate by fiffering amounts and literally give you a slow massage.
O
olimango
Thanks for the welcome all - and for the advice. I'll take a look and come back to you as soon as things are sorted.
Oli
gerryfh
Pulse Seats Not Working
Help any one got any ideas the pulse seats on my SL55 are not working, both seats don't work, red led comes on for a few moments on both seats but no movement, you cannot adjust either seat, when I operate the switches I can hear a clicking noise, but nothing else.
I've checked the cars fuses under the bonnet, and every thing fine there, suspension goes up and down too, are there any more fuses, is there a seperate pump if so does any one know where it is
You just need to plug the car into STAR go to interior, then seats, then check that the comfort seats are activated.
It is possible that a vacuum pipe has split,,and one can deal with that later, but at the moment I do not think that they are turned on
gerryfh
Thanks for that, but they used to work fine although the drivers seat was never brilliant, I've not used the car much in the last 6/7 months and the battery has been flat I've changed the engine bay battery and charged the rear I don't know if this has anything to do with it, is it possible do you think for the seats to turn themselves off as you suggest, the memory easy entry on the seat has only worked now and again.
Then they have turned themselves off,, and this could be due to a leak in one of the bladders or a pipe.
The PSE pump in the boot can only rune for 18sec max, in the event of a leak,, the SAM will turn the seats off to protect the pump.
Have it activated again, then blow up the bladders one by one and they should stay inflated for many days,, do check the vacuum pipes to see if they are kinked or cracked by raising the seat to max,,you can just see them
gerryfh
Thanks very much for the advise I'll book the car in next week and get the pump switched on, I'll let you know how I get on, its got to go in anyway as the soft clossing boot lock has packed in
100%Bitch
Norfolk 'n' good
Sounds to me that it's the pump at fault then.
Mic
Oxfordshire
www.bennettgibbons.co.uk
MB SL500(2003), MB SLK320(2001), Volvo V70 XC AWD(2001)
Hello and welcome.
Well worth getting the Comfort seats fixed....the massage function is very welcome on a long drive.
Mic
gerryfh
Thanks Mic, I'm one of these folks that likes everything to work, which is a bit of a pain with this SL55 as so much has gone wrong with it over the 4 years ive owned it, super charger, inter cooler, various water leaks, disks, steering rack !!!!! its lucky I love the car so can forgive it, I wouldn't mind but its only done 38k bought it at 7k when it was a year old :(
The pump is fine,, all outlets are called up on the CAN,, if any circuit operates the pump for too long,,it shuts that outlet down.
I know that the pump has turned itself off as I have had the same thing,,you push the massage button it stays alight for a few seconds and goes out
Mic
Oxfordshire
Ouch
Mic
I say that with my car too,,,just been investigating my can faults,, and I find that everything wakes up OK,, but there is a fluctuating voltage of between 1 and 10 volts on the CAN.
I can only work outside,,this make scoping very hard in the sun, so easier with a simple volt meter. I cannot do more right now as the car is needed this month, and the next stage could be all the seats and trim coming out,,but there is always something to do on a 230
gerryfh
Well I was fortunate with all my faults MB did them all under warranty, the super charger was an interesting one though I took the car in and told them that the car ran out of steam at 140mph !!!!! up till that speed you couldn't tell the difference, in fairness they diagnosed it straight away.
The only pain was when I had it back they must have down loaded updated software into the vehicle as my speed limiter was set back at 155 !!!! cost me another few pounds to get it removed.
Dean64
Registered
SL55 AMG
Hi everyone,
I know I’m piggy-backing on an old post, but I’ve just bought a 2003 SL55 AMG & I have the same problem, effecting both seats. However, I also have no light on the pulse switch, when it’s operated, so I assume it could be a fuse?
