zedmeister
- Sep 5, 2005
- Location
- Watford, Herts.
- CLK C208/2002/3.2, C Class S205/2019/220d, E class cab A124/1996/2.2
Noticed my car running a little hotter over the last month or so. It used to warm up to just over 80C and then it started running at 90C. Then it started creeping up but the other day, I had the red dash warning about coolant temp and when I looked it was as 120C. Had to park up for 1.5 hours before completing the last 10 mins to get home.
So I ran it up to temp on my drive. No fan. Temp creeped up to about 95. Fan does not go on even with a/c on. Revved the car up but is there a limiter as it would not go over 4000 revs on the drive. Could not get temp over 95 but some steam came up from behind the expansion bottle so I shut her at that point! But def no fan.
I presume that this could be for a number of reasons: fuse, fan, fan ecu, temp sender. SAM unit. Are there any more?
Does anyone have a logical order for attack? Also a list of locations for where these things are and any advice? I presume as the a/c did not switch the fan on that it is unlikely to be the temp sender?
I have checked the 5 amp fuse in the passenger engine compartment fuse box (F49) and this is okay but I thought that fan fuses are usually high amp fuses like 50A or larger? I seem to remember that C Classes have a pre fuse 125A that causes problems with the fan?
If someone has a list of things to check and where I'd appreciate it. My little bluetooth dongle did not find any codes on the car but thats hardly a proper diagnostic tool!
Thanks!
Thanks!
