SL55 vs Brabus SL Ride Height Issue
BRABUS R230
London
BRABUS SL55 K8 (R230), SL500 (R129), B Class B200 CDi, VW T5 Transporter.
Hi All, I have been away on holiday for a month and while away I left my car (BRABUS SL55 K8) with the MB Independent dealer to correct the ride height on the N/S front after the strut was changed, I wont bore all of the prior details as yet but I would like to know what the normal mesurement ride height is on a SL55 AMG so I can mesure it against my BRABUS tunel SL, my BRABUS has been fitted (from the BRABUS factory) the BRABUS Programmed Lowering module, this unit is installed by being soldered into the vehicles suspension ECU and lowers the car an extra inch below its lowest setting. Airmatic functions are still functional. the car will not drop lower than the lowest setting at speed.
Due to the drooping n/s front i was told that the all the suspension struts had to be done together, which i understand is correct, the problem is that i went to pick up the car yesterday and the whole car is now sitting higher that it was previously, the garage said that they only put in the cars paramiters on the star computer and did the "Rodeo" and that was it, but it appears the the Star system has over ridden the BRABUS Lowering Module setting as the car sits higher and they said that they cannot lower it any further as the star system does not allow it, is this true! if this is the case then perhaps they should have disconeccted the BRABUS Lowering Module then set it up using "STAR" to the SL55 AMG settings then reconnect the BRABUS Lowering Module, does my therory make sence?
they say that they do not know what the ride height of a standard SL55 AMG is to measure and compare it with to see how much out it is. I left the car at the Merc Independent to sort out
100%Bitch
Norfolk 'n' good
215 CL600, 216 Facelift CL500, 172 SLK55, Nissan Cube, R170 SLK230 & an Auto Trail Comanche.
Where are the measurements taken (wheel to top of wheelarch?, top of wheelarch to floor?, roof to sky?)?
teddycatkin
cheshire cheese country
Only one place will know (Brabus) thats where to take it --I am surprised you trusted it to anyone else in the first place?
70cm is the correct height for all the cars ,, we have another thread running on this issue
I believe that the lowering lowers by 2cm more for yours
You take them from under the edge of the wing, the only accurate place
BRABUS R230
BRABUS R230
London
there is NO BRABUS outlet in the UK, its all done by selected BRABUS certified MB Dealerships of which it has previously been to, they possibly had some 18 year old apprentice working on it
What is your VIN number please as there is nothing in the standard WIS that mentions the Brabus lowering module
type49
The ride "height" is not actually measured. You place an inclonometer-which measures angles from the horizon (bit like a variable spirit level) on specific places on suspension arms & driveshafts. From these angles you can calculate the ride height. These are all entered in STAR, with the car's own ride "height" sensors (which give the ABC control unit a varying voltage) If these angles are not in spec, STAR will throw a little tantrum untill they are corrected. You indie sounds like they are doing it correctly. There may, however, be a way of "fooling" the system, I have never acually tried though. In theory, if the arms which hold the car's own sensors are adjusted (bent) at the same angle & new inclonometer figures overwritten, this may fool the system with the lowered ride height. Hopes this helps a bit with the understanding that ABC ride height is not just a 5 minute operation.
BRABUS R230
BRABUS R230
London
Many thanks for your detailed info type49. does this then mean that "STAR" will try to correct the lowered height induced by the BRABUS Lowering module?
BRABUS R230
BRABUS R230
London
also, it it normal for the ride height to lower when vehicle is left stationary with the engine running after around 5 mins as this what happens to to mine, this has always been the case, even prior to this other issue.
I have found nothing on STAR for your car,, in the USA many have their cars lowered, and there are modules for this,,I am sure that these modules must be copied from Brabus do let me have the next numbers on the VIN after 230 and I can do a detailed search
BRABUS R230
BRABUS R230
London
what is your vin number please as there is nothing in the standard wis that mentions the brabus lowering module
Hi Television thanks,
wdb230474*******
OK I have already checked and nothing in WIS for a lowered chassis.. nothing at all in the 2009 version for this car
You can remove the VIN in edit on your last post
A
andy@pcd-ltd
The way i have done it before is to disconnect the brabus lowering kit set up the suspension as per the merc settingsfor normal ride height and then plug the brabus kit back in and it should be fine that way
BRABUS R230
BRABUS R230
London
i cant see the edit facilty
As type 49's post,,there is no real ride or standing height as such but we do know the 70cm from the wheel arch is the normal figure. I have been all through the whole thing this morning and as Willow132 this must be the only way to do it,,the module is not recognized as things are (is it plugged in) An Email to Brabus may give the answer.
You only have 2 hours to edit a post
Is there any reason why this could not be extended to say 24 hours like most other forums
I expect it is a setting in the admin panel, it used to be shorter in the previous version IIRC. I don't have issues editing emails & vins at posters requests.
Thank you and I can mention this,, I am always asking for Email addresses when it is not in the profile,, life is so simple when the Email address is given,,they get the info before i post back
