peter dunnett
- Jan 25, 2020
- Location
- Colchester Essex
- SL 600 2003 5.5lt
when opening the drivers door the handle released with a snap, I read the crank attached to the door handle was prone to snapping, I have removed the door card and this is the problem as half of the crank fell out when the card was released. I have purchased a replacement from my local Merc main dealer for £13.17 but I have a problem fitting it.
It looks like I need to take the door handle surround out of the door card to remove the pin hinge but the handle assembly is held in place by melted plastic tags, can I drill these out and remove the door handle if so how do you refit the assembly.
Any help gratefully received.
