Sleeping in...
idlerider
Dornoch, Highlands
2006 T211/E350 petrol wagon
W211 estate. Early morning cold start. Seat heater and rear demist lights flashing but not working; tailgate not working either. After a couple of miles, everything comes on-line again. Normal? - or do I need a new battery?
Sounds like battery from what you’ve said
joderest
ML270 2003
I think you will find that your right hand side giggle socket has detached itself from the left hand side giggle pin !!!
Or it could be you need a new battery
Exactly the same symptoms my 230 gives when the consumer battery is flat.
mioba
Nottingham and Köln
Does the car struggle to start. Does sound like the battery.
The cars tend to shut off certain high power demanding appliances when the battery is low.
check the voltage before start and when at idle to determine if alty is fine. however it does seem based on what you described already.
idlerider
idlerider
Dornoch, Highlands
Should have said: starts, no problem - turns over quick and fires immediately. Or do they have two batteries?
mioba
Nottingham and Köln
No idea if your car has 2 batteries, maybe one for auxiliraies, RTFM as they say :)
idlerider
idlerider
Dornoch, Highlands
Thanks for your helpful reply. The Forum is indeed fortunate to have such knowledgable and courteous members.
Oldspanners
Normandy
C CLASS 2004 C180
What age is the battery?
Have a look at the terminals, just changed mine it was stamped 06 08 almost 12 years and it still started no problem after sitting outside for a few days but started to throw odd spurious faults.
V6Matty
Newark, Nottinghamshire
S211 does indeed have two batteries, give them both a charge and see how you get on, my previous 211 did this once, have them both a good charge and never saw it again.
V6Matty
Big one in the boot and the other smaller aux one in the engine bay, near side rear IIRC
