Looks like someone been there already, little flap is open with some electrics and a white wheel which looks like a screw, now my torch has gone flat, but have to keep trying, is their an altenative to this key?
well' i'v been turning the small grooved plastic wheel by hand but the roof isn't moving, the wheel, which has two arrows on on it with words in german turns quite easily when pulled out slightly, it clicks into a middle possition, if i pull it a bit further it clicks again but doesn't turn, so unless shouldn't be pulling it out it doesn't appear to be working?
Yeah i did pull that off and the pins were like new, i'll try some wd40 anyway.There is a relay/module in beside the manual closing thing. Pull it out and clean the pins with WD40 and your sunroof will be like new (if you can remember that far back)
ps. hey, she's only going on 18 and looks new!Yeah i did pull that off and the pins were like new, i'll try some wd40 anyway.
AFAIK they're the same for all models, apart from detail differences as notedDoes the 95 w124 have the same system for manual closure of the sun roof?
