slight rocking at idle W203 C220 CDI 2002
WAB
hi guys I have a slight rocking motion at idle. when I pull away there is no sluggishness or faltering, but it is noticable, any ideas?
Bill
W
WAB
Kevin is that the MAF?
too_juicey
W210 E320 cdi Avantgarde (2001)
Yes, the air mass sensor is also known as the MAF. Get one from MB, there is only £6 difference between that and one from specialists (as I found out today)...
malcolm E53 AMG
Had the same problem as you, engine rough at idle only. Turned out to be worn injector nozzles, two needed replacing so did the lot. If its not the MAF this is most likely the problem, see your local BOSCH diesel specialist, seems to be an inherent problem with circa 2000 reg cars. Expect £115 per nozzle for replacement.
hardtop
south of glasgow
have to agree injector fault poss seal or nozzles
www.W140.co.uk&www.r129.co
