Slk 170 turning into a swimming pool
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by craigbaker010469, Nov 1, 2012.
  1. craigbaker010469
    craigbaker010469 Member
    10
    Nov 29, 2009
    The other day my blowers started running with the ignition off so I took the cover off and removed the 3 pin connector. There were damp leafs in the cover and filter so I guess I just need to replace the resistor??
    This morning I got in the car it had been raining all night and the car was parked facing down hill. As I reversed about 2 pints of water poured out from under the dash??? Where is this getting in? Is something blocked? If I don't sort this I will need Wellington boots to drive the car.
    TIA
    Craig
  2. television
    television Always remembered RIP
    164,074
    310
    Your Mercedes:
    It is the heater box drain that is now blocked its 320 and it comes out under the nearside wheel arch
    [​IMG]
    You do have the water baffle with drain hoses that need to be cleared it in front of the screen
    [​IMG]
  3. OP
    craigbaker010469
    10
    Nov 29, 2009
  4. television
    164,074
    310
    Your Mercedes:
    They are all the same and the diagrams are for the 170
  5. OP
    craigbaker010469
    10
    Nov 29, 2009
    Thanks your a star, if it stops raining I will tackle it
Share This Page
