Stevitee
Gave the car a thorough wash and clean on Sunday. On Monday both headlamp lenses had condensation (were wet) inside. I have seen a thread on here but can't find it again and understand that if I turn the lights on for a while they will dry out and all will be well - I assume, until the next time it rains or I wash the car. (The former being the more likely this BBQ summer!).
Anyway assuming the lights are venting correctly - I will check - the cure I have seen suggested is to remove the lense, clean the gasket/seal and replace, perhaps adding a bead of silicone. My question is, can the lense be removed with the h/lamp unit in situ or does the whole unit have to be taken out before one can remove the lense retaining clips?
Avoiding removal of each unit would be preferable but I'll be guided by you guys. What's the best approach please.
Many thanks
Many thanks
