Slk 230 interior light
MERC210
HERTS
B CLASS 200 CDI AND e 320 cdi sln 2006 facelift
IS THERE ANYONE WHO HAS THERE INT LGHT NOT WORKED AND SOLVED IT BY GETTING HE HELLA BOX REPAIRED ,IF YOU HAVE SORTED IT CAN YOU SEND ANY INFO OR REPAIRES TO ME AT colin1417@yahoo.co.uk THANKS VERY MUCH
Do you mean the OCP what is wrong with it
MERC210
MERC210
HERTS
Ocp
Hi not sure what ocp is as far as i know its the black box in the o/s boot area that also works the locks,its a hella unit
MERC210
MERC210
HERTS
Re fault
Hi malcolm
i did take it to my local mb dealer and he said it was that as i can only switch the int lght on at the switch ,dor switches have no affect
This needs a little more searching,,and I will try in the morning
Alex Crow
Super Suffolk
certainly sounds like water in the pse unit. i am fitting one this week! same symptoms, stripped down, cleaned pcb and unseized pump but still only half the functions work (eg central from remote, not from dash switch etc). a sad story and all too common, i will be fitting the pup upside down as per common mod.
Just make sure that it can still breath:D
MERC210
MERC210
HERTS
Re light
certainly sounds like water in the pse unit. I am fitting one this week! Same symptoms, stripped down, cleaned pcb and unseized pump but still only half the functions work (eg central from remote, not from dash switch etc). A sad story and all too common, i will be fitting the pup upside down as per common mod.
can you let me know if cleaning the board got the int light working cheers ,merc210
Alex Crow
Super Suffolk
wouldn't you know it, that was one thing that did not work!
Specialist Car Insurance provider in the UK offering cheap car insurance quotes for all risks including Mercedes cars.
