sailorP
- May 19, 2008
- Location
- North Herefordshire
- SLK32AMG
This is a 2002 R170 SLK32 AMG.
I've just put her back on the road this afternoon after nearly six months on a SORN and I had a bit of an issue with the brakes.
When first started and moved on the driveway, slow speed manoeuvring felt a bit odd, the car was reluctant to move without a prod on the throttle.
Then noticed that brake lights were on while stationary, in Park, without handbrake on.
Hmm.
Next noticed that brake pedal was not in fully up "off" position. I could lift it with my left foot an inch or so, back to it's proper "off" position. When lifted, the brake lights were extinguished.
When re-applying the brakes fully again and then releasing the pedal, the pedal again didn't quite fully release, and brake lights stayed on. The pedal could be lifted with left foot, so I set off on a short run to see what else was wrong.
Nothing else found. Brakes operated fine, brought car to a halt very effectively, but the pedal had to be lifted with left foot after every application, to bring the pedal fully up and release the brakes fully.
Has anyone any previous experience with this issue, or a possible diagnosis and fix?
And, yes, I know, I shouldn't really run with brakes even remotely dodgy, but it was a short run to attempt to diagnose the problem and see if it self-cleared (it didn't). Apart from a sticky hood (solution for which is on another thread) that's the only issue.
She's booked into Gerry Dovermans Hereford for B service plus spark plugs, filters and MOT in a couple of weeks. I won't be putting her on the road again until then. But I'd like some advice on this brake issue so I can sound semi-proficient when I discuss the problem with them.
I'll be reading this thread every evening, no rush for solution.
Thanks Phil
Hmm.
Thanks Phil
