Slk _ Indicators Not Fashing
MIW615
Leafy Surrey
C200 SPORT & 230SLK
The wife's SLK has an intermittant problm with the indicators, very simply occasionally they donot flash, the light come on the display and outside lights are on, no "ticking" - but no flashing. :mad:
I't not the PSE unit - it's dry and been turned upside down, I have change a small control relay that was recommended by MB, but there has to be something else that controls the indicators.
If this was a Morris 1000 changing the flasher unit would solve the problem - but as far as I can see there is no such thing om the SLK
Help / advise please
malcolm
See what I can find at sun down and moon out time
Vangogh
Beckenham Kent
E350CDi 2012 3ltr Diesel
Hi Malcom
I have got this problem with my SLK. I have found that if you put the windscreen wipers on intermittent it clears the fault. I believe they both work from the same module.
MIW615
MIW615
Leafy Surrey
C200 SPORT & 230SLK
Hi Malcom
Thanks Vangogh for the tip - do you think it's the module that is at fault - where can I locate the module on the car?
MIW615
MIW615
Leafy Surrey
C200 SPORT & 230SLK
Black C55 - have you ever had this problem?
Malcolm
BlackC55
South coast
C43
Malcolm
Yes.
9/10 it isthe multi-function relay that is the problem (more like a control unit).
It operated the roof and the wipers too.
MIW615
MIW615
Leafy Surrey
C200 SPORT & 230SLK
Yes.
Thanks for reply - where do I find this relay - any chance of a part number
Cheers
Malcolm
MIW615
MIW615
Leafy Surrey
C200 SPORT & 230SLK
BlackC55 - would this fault be stored on the car#s ecu and can it be diagnosed through star?
Malcolm
MIW615
MIW615
Leafy Surrey
C200 SPORT & 230SLK
Malcolm I don't think so that's a switching relay for the flashers, which I have already replaced
(£9.00) - I think the multi function relay is a much more complex relay / control unit that costs ££££ :roll:
I will find it this eve
You have a PM I need your Email address
Vangogh
Beckenham Kent
Hi Manlcolm
Sorry I don't know where the module is, but I have heard it is not cheap.
MIW615
MIW615
Leafy Surrey
C200 SPORT & 230SLK
  • #18
Hi Manlcolm
I have heard it's over £500 :( - what I would like to know if it can be taken apart (like the PSE unit) and cleaned - could anyone advise
Thanks in advance
All of the modules can be taken apart, whether or not they can be fixed is something else
I have the details for you but I need your Email address
MIW615
MIW615
Leafy Surrey
C200 SPORT & 230SLK
  • #20
Thanks for e-mail Malcolm - if I remove / replace the muliti function control module does the car have to be put on "star" or is it self calibrating?
