Slk sticky tappet
mercmadjim
Cornwall
SLK230k
On start up, my 97, slk230 has a noisy tappet, the car is not used much, and I was wondering if there was an additive I can put in the oil to help the situation?
Is it there all of the time,,have you taken it out for a run
mercmadjim
mercmadjim
Cornwall
SLK230k
Hi Malcolm, it stayed for about 20 minutes, I was talking to a chap I know, car ticking over, and it just went quiet, and then was ok for the rest of the day, new oil and filter was done about 6 months ago, but it was done by the same Mercedes "specialist" who fitted the wrong plugs and lied about my other "faults".....maybe he has used cheap oil??
jibcl500
Cambridgeshire
CL500,ML55,SLK280
take the car out for a drive and then change the oil to mobil 1 and a fresh filter.
jib
Zebra
Yorkshire
C220CDI
If it is still sticking you could try a bottle of Forte Top End Treatment which is good at sorting "lazy" tappets.
Mr Teddy Bear
Bristol Between Mill & Cutting
1998 W208 CLK 230K SPORT: MG F 1.8VVC: Flame Red Rover 216GTi
I don't like oil additives a good oil shouldn't need them and I believe that Merc warn against in the owners/servicing schedule. I have found however that using an oil flush before an oil change works wonders for sticking hydraulic tappets.
