slk wheel offsets??
T
True romance
wolverhampton
slk280 (2008 face lift)
Hi Malc, just read on another forum that the ET needs to be different on the front and backs, is this true??
The wheels do not have to ,,on the chart this shows that some do and some do not
The wheel width dictates if the ET will change.
You could put up the other figures like width and diameter of the one that you want, and I could tell you more.
But they are all in the chart
T
True romance
wolverhampton
8.5 J X 19" 5X112 ET35 ( fronts )
9.5 J X 19" 5X112 ET35 ( rears )
thanks, I still can't get my head round the ET figures :confused: If i've got this correct the 8.5j can only be ET28-30, but the rear 9.5j would be fine with a ET35??
Yes you have it correct,,but it should not be a real problem.
the higher the figure the more they will sit inwards, and in this case that is only 5mm, but will the 5mm mean that the wheels will clear the calipers
T
True romance
wolverhampton
can anyone else confirm if ET35 front and back will work?? looking to order this week.
Thanks,
TR.
