Steve Magee
- May 17, 2019
- Location
- Mold , North Wales
- slk200 2003
Hi folks this is my post . I have a 2003 SLK200 auto. its been sitting over the winter. It was last used in November. I was returning from a short journey ,when I got in the car it didn't want to start kept cranking over . it eventually started in went into limp mode. Drove home turned out to be a speed sensor ( generic obd reader doesn't say which one ). the following day didn't want to crank over at all. Checked all the obvious things like earth straps etc. no joy so I left it over winter.
Im trying to sort it now the weather is starting to perk up. I have reset the fault codes and its currently not showing a wheel sensor fault .However It wont go into gear ( the classic brake switch fault ?)
I have taken the lid off the box containing all the electronic bits , to my surprise it was quite wet !!!
got rid of all the wetness and moist . took out the k40 box hoping for some dodgy solder but it looks in very good condition the only components on the board are a few resisters and a diode. the diode is ok (metered). fuses ok. Relays move as they should. Even though its not showing a faulty speed sensor if this was still an issue would it inhibit the starter motor, if the you move the interlock to neutral it still wont start. oh i've also flicked the central locking on and off a couple of times just in case it might have been some quirk with the key.
I supposed it could be a knackered starter motor, if you stick a meter on the battery and turn the key its not drawing any current. Is there a way to check the feed to the starter from up top ? I don't mind having a go if someone could put me in the right direction. This car was super reliable until it wasn't
Many Thanks
Steve [Mold, North Walles ]
Many Thanks
