Colleyv12
- Jan 16, 2017
- Location
- Argyl Scotland
- 2000 SLK 230 R170 Facelift
I left the SLK to stand for about a year, when I came back and charged the car up, I noticed that the indicators continually flashed until I put the key on the ignition and turned to position 2
Everything work fine when the car was put away, stored in a dry garage.
Opened up the alarm siren under the bonnet and the internal connector had black deposits all over and a corroded circuit board but the battery location looks OK
Also, when the key fob buttons are pressed, the indicators flash to show the alarm activating and disabling, but the central locking does not work and when you open the door after arming, even when disabling on the fob, the indicators flash quickly again until the key is inserted
I bought a used siren of ebay, but that makes no difference and there is no water in the PSU in the boot.
Could it be the alarm control unit, or syncing issue, the roof works fine, and the central locking works from the button on the dashboard, but it does not work from the fob or key in the door
OBD reader shows no faults, but it is a cheap one
Any help would be appreciated
