Mikimogo
- Feb 26, 2007
- Mercedes C220 CDI Yr2000 w202 engine 611960 (OM611)
Hi all,
I have had a C220 CDI W202 Yr2000 since March and it is really slow at setting off from a stand still. If you're at a junction and acellerate to move off it is really sluggish for 2 to 3 seconds and then it kicks in I've changed the glow plugs, tried starting off in fist gear manually even though it's automatic and even tried knocking the ESP off but nothing makes any difference. I've also put it on my computer using Carsof 7.4 and no fault codes come up, it can be quite dangerous at times because you have to put you're foot down before you actually want to move off. Has anyone else had this ptoblem and if so what is the cure?
Any advice will be appreciated.
