Smelly air/con
vanalan
STAFFS
Hi guys is there a pre filter that can be changed on the air/con, the system works perfectley and was serviced mid last year, the day after using the a/c the smell in the car on start up and for 10/20 mins after is discusting its a resin come (cat pee ) smell any help please thank you
racall
london
c class and slk
Lidi A/c
Pop down to your local Lidl store and get a air conditioner deodoriser (about) £2.
Put it on the rear tunnel and set it off with the A/C on recurlate.
Phil D
Edinburgh
previously W202 & W203
how old is the car? the only permanent solution could be a lot more complex / expensive than this - a two day job stripping the dash out and replacing the evaporator - it is covered by warranty though so I hope you're in luck
AndrewIles
Alton, Hants.
SLK 55 AMG
Sounds like bacteria in the system.
The air con deodorisor should sort it. You can also get it from Halfords but from memory £10 a can.
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Before using the system cleaner replace the pollen filters(s) first.
You do not say what the car is,,but the kits from Halfords work well
V
vanalan
STAFFS
Sorry guys should have given more detail, my car is 06 C180 K only done 30k thank you
Phil D
Edinburgh
The various cheapo solutions may work & I hope they do for you - in my case it didn't - at a similar age & mileage to yours
I hope you are still covered by warranty & if so get down to the dealers pronto & report the fault
it's known to MB and there's a pre-determined protocol to solving it, which basically involves taking the car in - 3 or 4 times from memory - while they try successive solutions which don't involve replacing the system
eventually they give the go ahead, which as I said before, is a 2 day job costing stupid money if it's not under warranty
www.W140.co.uk&www.r129.co
