I noticed my brake pedal is getting softer. If I pump the brake seeral times it stiffens and brakes better.
There is no obvious leak anywhere, nor does it consume brake fluid. I bled the system thoroughly, few days ago but this did not improve the situtation. My diagnosis (and fear) is I need a new master cylinder. How could I be sure? If a seal is leaking on one of the wheel cylinders would I get similar symptoms?
Which one is it?
A new master cylinder is around GBP150, and I plan to replace it myself.
I did not expect a failed master cylinder at 80k. I never had similar problem on other cars. I am getting into a stage where I am fitting a new component on my car every month!!!
Thanks in advance for replies.
Regards,
Pose.
Which one is it?
Regards,
Pose.
