Soft top malfunction R129
hakulmi
Hi!
First, Thank you all, This has been very helpful site to me. I bought SL500 -92 lately. I have a small problem with soft top.
I am living in Finland and we do not have so many R129 cars in here.
Soft top goes back to trunk always without problems.
When I start to lift soft top on, it goes nicely to half a way then it stops (always in exact same position) Then I have to move it all the way back and start again. Sometimes it goes with the first try Sometimes I need 5 tries.
It is not jammed.
Thanks in advance
By the way, we have Summer here.
-280 SLC -76
-500 sL -92
Normally a window reset does the job for this fault.
Malcolm
markmerc
If you have a local merc mechanic, get them to test it on a diagnostics computer. It could just be some of the micro switches. Or unfortunately the hood contoller itself, a very expensive item!
H
hakulmi
Problem solved
It just needed a grease and cleaning to top of the windscreen holes. To locking pins and sensors. No problems after that.:)
A very good lubricant is the PTFE/Silicon sprays that is used for router cutters is very good,it does not stain or leave any mess, I did my 129 with it,it makes a big difference.
Malcolm
