230ceBruno
- Dec 12, 2005
Further my previous post re: Clonking see this link: http://forums.mercedesclub.org.uk/showthread.php?t=26803&page=1
It cost £400 plus most of it unnecessary but I have sorted out the main cause of the clonking.
It turned out to be the center prop shaft bearing but now realise the reason for some of the varying and unrelated symtoms I exeprienced which clouded the diagnosis.
I said I heard the noise over my right shoulder to the rear: this part was because I idiotically had a can of grease in the boot that was knocking against the side walls.
I said that vibration was felt in the center console area below the arm rest, actully approx 1 foot rearward from that area. This was due to the the center prop shaft bearing being worn.
however I also said that I felt a jolt in the steering whilst streering to the right leading to the unnecessary change of the lower controlling arms.
I havent felt the jolt since the change but there remains a noise and mild jarring that seemed to occur in time with the clonking before the bearing change and this caused the confusion in isolating the problem.
The jarring happens when I brake to a full stop and is felt thru the brake pedal.
It is also felt beneath the foot rest (left) at same time and somtimes when the car exeperinces some kinds of bumps in the road, usually small ones that that dont bring the dampers to kick in.
When I make a hard turn i.e. more that 60 degrees there is a click thats almost a clonk but not quite. And when it happens, I can imagine the click to come from somewhere at the end of the the steering column where it might meet the fron axle......:-?
Any ideas?
Any ideas?
