Spare key wont lock or unlock the car
Eduardglc
Mercedes benz glc 250 d 4matic, 2018
My spare key won't lock or unlock the car. I can start the engine with the same key but just can't lock it or unlock it. I have always used the main key and the spare key has been in the key wallet signal blocker which has hardly been used.
Any tips would much appreciate it.
Ed
E
Eduardglc
Thank you. Do you know if the batteries recharge when you use the key everyday?
SmartAmg
2011 E class coupe 350 CDI
Welcome, Eduard. :)
As above they are disposable lithium cells (CR2025 from memory but could be wrong).
Naraic
2005 CL500.
The only stupid question is the one not asked.
Naraic
2005 CL500.
A non rechargeable battery is used for locking and unlocking the doors. A battery in the key is not required to start the car.
They are CR2025's
As an aside the "25" bit identifies it as 2.5mm thick - whereas a CR2032 would be 3.2mm thick
E
Eduardglc
Thanks everyone! Appreciate your prompt responses. The battery was dead so I changed it and the key worked fine. You are correct about starting the car even when the battery is dead. Mercedes me app very useful in these situations.
