Spark Plug Change
wayneC320
London
Mercedes C320
Hi everyone,
I have just had a quote of £217 to replace my spark plugs on my C320, please can someone let me know if this sounds about right.
Thanks.
If that includes the plugs (12) then OK I think
W
wayneC320
London
Mercedes C320
Hi Television,
includes the 12 plugs and two hours labour. I thought this was rather expenseive! Is it a hard job? does it take two hours to change them?
Thanks for your help as always.
Cole@MBS
www.mbssouthampton.co.uk
It dont take 2 hours to change them!!!
I have seen it done in 20 mins,,I would do it in 1 hour ish.
It can depend on how they go about it,,the safe way is to remove the coil packs, and this can add to the cost.
You could do it your self,,you lever the plug caps off over the top of the head with a cranked 17mm open spanner.
Lets see what some others say
rpe2
Silchester
E53 Estate, 124 Cabriolet, 129 SL
Colin will do it in 2 minutes for you :D
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
The 2 hours they quote is probably the book time from MB, if you are inclined to do it yourself there is a link somewhere on here to a very informative "HOW TO" with pics that takes you step-by-step through the process.
W
wayneC320
London
Mercedes C320
Thanks guys, i am not very handy with a spanner so unfortunately will have to give them the go ahead to do it. I just thought it was a bit on the expensive side for changing plugs.
Ask them to lower the price,, the London weighting can put the price up
SilverSaloon
w124/1994/om606
i replaced my 6 spark plugs in about 20 mins. if you are doing it just ensure you screw them in by hand to begin with to avoid cross threading & if possible, use a torque wrench at the end.
the 20 mins i took didnt take into account cleaning the spark plug area etc before removal. my engine (M110) is a nightmare for this but yours may not be as bad. IMO well worth doing along with cleaning of the HT leads at the same time.
definatly a job you can do yourself anyway - 6 sparkplugs (BOSCHE) from the main dealer for my R107 was £12 from the dealer! The plugs are probably more expensive for your model and you need more (i think) but still worth doing the labour yourself, if you are happy to get stuck in
