Submariner1
- Sep 3, 2016
- Location
- Windsor Berkshire
- CL500 2009 5.5
I did this quickly about 2 weeks ago just using a powerful 2,000w Industrial wet and dry vac..
One drains perfectly the other a little slower.
Subsequently seen a picture of the drain tube on EPC, at the end of a single tube for each front drain is a Reed Valve.
My thoughts
- strong suction would pull that shut, add the constriction of a thin tube .... suction will not be so effective, but safe in that it wont push the tube off the frame outlet
As my experience of bathroom drains is, its either whistle clean, or you are at risk, i.e. you get it draining pretty well , and then the sludge moves and totally blocks it.
Whats the best thing to rod the drain with?
1. 1.5mm strimmer wire, looks to be too bendy? and my stuff was wound on a small spool, so very curly.
2. Go and buy some 2mm diam stimmer wire. Hopefully not so coiled.
3. Note I carefully tried some 1.5mm2 electrical wire, circa 3.1mm OD, having first pulled the sheathing so the plastic sheath end covered the copper wire strands, i.e. to protect the drain tube.
Being paranoid about pushing the drain tube off the Sunroof frame spigot, I pushed very very gently and it went in about the length to get it 1/2 way down the A Pillar.
And then I could feel a very slight bit of resistance, so stopped.
4. So I then tried 1.0mm2 wire, circa 2.7mm OD. Oddly one felt slight resistance at exactly the same place, same result the other side (note this is the side that runs extremely freely ... so the slight resistance is not likely to be muck built up in the tube)
Coincidence or would they reduce the bore ? Note the hole in the sunroof tray is about 6mm to 7mm ID.
A bit confused as the EPC part diagram just shows I long tube, so why would it stop 1/2 way down the A pillar??
No advice on WIS , well I cant find it.
Only to say that on cars built post August 2008, one must replace the additional cable tie on the tube pushed onto the frame ... obviously lots were pushed off.
Luckily mine should have that.
Or is it case that I just need to push harder.
Sensible answers appreciated as I am sure Nairac would love to see me push the drain tube off the frame
Any safe tips welcome.
Water seems to drain out of the triangular cut outs, on the rear part of the front wheel arch liner, about 6” up.
Is the reed valve located just above this cutout, on the car side of the wheel arch liner?
My thoughts being to push up from the lower end.
My thoughts
