Sprinter 316CDi sprintshift - black smoke
carlmt
Gillingham, Dorset
Sprinter 316
Hi all,
New member here, with Sprinter 316CDi motorhome.
You have probably heard it all before, but can anyone point me in the right direction of a cure please?
Just recently, our van has been kicking out black smoke on accelleration (and cruise) and seems down on power / torque. It will get up to speed, eventually, but doesnt seem to have the power it used to have.
I dont THINK the turbo has gone (hope?), but am baffled as to the cause.
Unfortunately, the van does get laid up for about 3 or 4 months at a time.
Any ideas folks?
Cheers
Carl
Cole@MBS
www.mbssouthampton.co.uk
Sounds like a spilt boost pipe, cheap to replace
Welcome to the forums
C
carlmt
Gillingham, Dorset
Sprinter 316
Cheers for that!!! However, if it is split, then it must be microscopic as I didnt notice owt yesterday when looking very closely..... Will look again this evening....
Got me really worried has this.....
Engine has only done 29K on a 55 plate.....
Carl
C
cyg
Hi all,
Any ideas folks?
Cheers
Carl
Hi i run similar base vehicles i once had this exact prob with a
citroen relay the cure a good dose of redex that cured power & black smoke i still own the vehicle now on 95,000 . I now add abottle to all of our deisels twice a year i wouldnt worry about overdosing if your tank isnt full . Worth atry otherwise as alreay advised ,had that on a fiat based Autotrail would not make 50 mph. Laid up for months not good ,is it poss to drive it 60 miles or so every 2 weeks ?
Roxie
Lincolnshire
C Class 350CDI 2012
I would get it to a star diagnosis machine before you start waisting money you need to see what fault codes you have.
After the cold weather we have had and perhaps as you don't use all year round, you could have some summer grade diesel still in the tank that is waxing and a new fuel filter may help.
C
carlmt
Gillingham, Dorset
Sprinter 316
Hi - sorry not got back....been out of the country for a while.....
Not with the motorhome unfortunately....
Cole.....is it ok if I give you a shout around February to book the 'van in for ssome diagnostics on this problem please?
Cheers
Carl
C
carlmt
Gillingham, Dorset
Sprinter 316
OK - further update on this now that I have had a bit of time to try and sort it.
Absolutely nowt wrong with the hoses that I can find - all tickety boo and tight, no holes, no splits....nyadda!!!
Air filter changed - no difference.
Turbo spins freely and no play in the bearings.
Good, fresh diesel in the tank.
Now really stumped on this.
Have tried to contact a few independents locally, but all say they cannot accommodate me as the van is too large for them. Anyone know of SOMEONE who can either take the damn thing in or is mobile enough to come and take a look? The van is in Gillingham, Dorset and is driving me beserk!!!!!!!
And if it is injectors - are they really nearly £200 a piece!!!!!!
Look forward to hearing the wisdom folks...
Carl
stumo
VIC, Australia
ML270CDI x3 2002,03,04 | Sprinter 316CDI 2003 LWB
Check the turbo actuator linkage is not sticking.
