F
FrankiaMH
This is my first post on this forum so here goes,
I have a problem with the brakes on our 2003 316 sprinter based motor home which has clocked up a grand total of 38,000 miles (hardly run in!). The brakes have always been spongy, typical sprinter but not a problem until recently when the pedal goes almost to the floor when it is pressed fully down. In reality there is not a problem stopping quickly but it is very disconcerting!
When the engine is not running the pedal is rock solid and perfect, start the engine and the pedal falls away. My first thought was the servo, but there is no indication of any leaks in the vacuum and the level in the reservoir has not moved since the fluid was renewed (2007) There are no visible leaks of fluid from any of the pistons or hoses.
Perhaps the master cylinder internal seals are letting the fluid back into the reservoir under the heavy pressure from the servo or worst case its the ABS modulator internal seals and that’s expensive!
I have found various threads on this site that have had similar problems and I wonder if anyone has had success curing this before I start work on the van.
Thanks, Neil
Thanks, Neil
