Sprinter Srs 2011
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by maxsprinter, Dec 4, 2012.
  1. maxsprinter
    maxsprinter New Member
    7
    Feb 9, 2010
    Ive got a 313 had a good smack to rear and front corner all straight and good now but srs is on. Scanned it on Solus and it says resitance fault on all three seat belts. For them to fire does the seat have to be sat on? Is there any visible signs they have fired as I dont want to replace all three to find out its somthing else!
    Many thanks
    Max
  2. WG M-B
    WG M-B Senior Member Authorised Forum Supporter
    3,105
    6
    Dec 5, 2010
    North west london
    Your Mercedes:
    C63 Wagon in black
    All three of the pre tensioners would have fired and the srs unit will also need flashing
  3. OP
    maxsprinter
    7
    Feb 9, 2010
    Hi ,
    OK so 3 replacements, srs unit flashing you mean resetting?
    Max
Share This Page
