Folks,
Hopefully this post will provoke less heated debate than my last ;-)
Quite simply, on my W211 E320 CDI, the driver's side door mirror makes a less than loveable noise as it swings in / out as you lock / unlock the car. Merc have tried spraying loads of what I guess is WD40, to no avail.
I have the usual 12 month approved used warranty, and have told the dealer that when it goes for service it needs looking at, but they so far have ummed and ahhed over whether it would be a warranty item.
Surely, it'd only not be a warranty item if it came under "normal wear and tear" - and can anyone really claim that something like this can be claimed as normal wear and tear?
I've also heard this is a known and fairly common problem - anyone else had the same? Was that a warranty fix?
