Squeaky suspension W124
MikeCoupe
Surrey
squeaks when driving. It appears to be on the passenger side, i can hear it when the windows down, and im driving past a wall or something. Doesnt seem to be affecting handling. Any ideas?
Ive heard a w124 with a similar sounding problem before. Perhaps its a common problem?
wireman
lancashire
Sort it quickly, it makes a real mess if the wheel comes off and you run over it.
MikeCoupe
MikeCoupe
Surrey
nasty. How much will that cost me, before the wheel falls off :p I has only just had an MOT when I bought it. Should they not have been checked for that?? :?
47p2
Scotland
W638, W140, W220, W639 All gone but not forgotten
They don't need to be worn with play for them to squeak. Water gets inside them and they seize without showing signs of wear. You should change them as soon as possible.
If they do go when the vehicle is being driven it will make a mess of bodywork and suspension
47p2
Scotland
expensive job?
I really haven't a clue Mike. It will depend on who you get to do the job and where they source there parts from.
I am a bit of a stickler in the parts department as I always buy from the stealership. I have over the years found that aftermarket spares do not last as long and the quality is often very poor
MikeCoupe
MikeCoupe
Surrey
Fair play. Cheers anyways. Ill see what the dealer I got it from says, they gave me a warrenty with it on non wear-and-tear parts... and they did sell it to me with a new MOT, and that should have been picked up surely.. Perhaps, perhaps not, we'll see. Ill call them anyway and see what they say, these warrenties are usually worth bugger all though. Otherwise I guess Ill have to get it done somewhere else.
47p2
Scotland
When did the car get the MOT?
47p2
Scotland
Not sure but I think there is a cut off date for MOT problems. I think it is 4 weeks. No doubt someone else on the forum will let you know
MikeCoupe
MikeCoupe
Surrey
oh yeah i wasnt thinking about challenging the MOT findings or whatever, I would have thought theyd have picked it up is all. I was saying that I have a warrenty for the car from the dealer. I should cover it... But who knows. lol
Cheers for the advice, I didnt think it was a serious problem really lol, good job I thought I should get an opinion though
robh
Durham City
Drive belts ( ie alternator drive etc.) can produce an anoying squeak.Get a can of belt dressing and give
it a spray.
MikeCoupe
MikeCoupe
Surrey
My balls are ok! I dont need new balls :) I took it to my garage and they said theres no play in them, and theres no evidence of water getting in them, which apparently causes a powdery residue to come out when its dried. Its stopped squeaking so they just said to bring it back in if it starts to do it again.
Also, on a plus note, the mechanic said it looks like Ive got a good one :) which made me happy
Thanks for all the advice though.
kth286
E320 Coupe 95
Mike
Could be the rear brake caliper sticking on slightly.
It is a recognised fault and the reason it is intermittent is because gradually (in the early stages of starting to stick) they do release themselves.
So, for example if you drive past your wall or hedge just after you have applied youir brakes the rear brakes pads will still be rubbing. Hoever, if your drive past the wall/hedge and you have not recently applied your brakes the noise will not be there because they are not sticking this time.
As time goes on, the sticking will get worse and worse and you will either need new calipers or have the internals changed with the Mercedes refurb kit.
BlackC55
South coast
C43
it a spray.
NOOOOO. Never use belt dressing. It goes everwhere and is 5hite.
JIZZSTER
Banned
ESSEX
W124 COUPE TRY spam removed spammer banned WEB FORUM FOR W124 COUPE AND CABRIOLET OWNERS VERY FRIENDLY
STEVE
