Hi , does anyone know how to cure squeaky window seals ? I have tried Teflon dry lube on the runners , no diference. What do you use to lube the seals that touch the window?
No it won't smear, and yes he is sure, WD40 is nothing short of a wonder product, in nearly 30 yrs experience, i've yet to find something on a car that it harms!!
Dow Corning MS-4 Silicone compound? Marvellous stuff, I'm in the Saturation diving industry and we use this silicone based compound on all our lip seals and o-rings on our castellated hatches to protect, pro-long, seal and prevent the rubber compound from brittleness ! I?ve used the product on all my Motors?s window rubbers to preserve and stop binding.
Have to agree I use Dow Corning coatings at work and they're fabulous , If you get hold of some try this...
Clean your tyre side walls , let them dry , spray them with Dow Corning Silcone , let it dry......
result.... nice shiney black tyres that don't dull or go grey .....ever.....
It works , we used to do it when I worked for Ford....
cars can sit out side for months and still have tyres like new...
carfull though DON'T get it on your Brakes or on the tread of the tyre.... or you wont live another day...
This is a common fault on W202 mercedes all years, although I have heard rumours they changed the rubbers after 1997/8 so dunno... I know you can get a felt fix for this
You lost your key ? Or maybe you need a spare!
Your vehicle imobilliser does not respond anymore?
WE CAN FIX THEM ALL !! Mobile !
Save Time and Increase Profits With us !
