srs light
merk
northern ireland
1994 w202 c200 mercedes and 1939 morris 8 e series
hi guys my first post
ok ive got a 1994 c200 mercedes elagance and im putting it through mot on saturday
problem is my srs light wont go off for at least 1min after car has started
dont know if mot testers will say anything about it though
thanks:D
Hello and welcome,,the SRS is not part of the test as I see it,,the ABS is though
merk
merk
northern ireland
thanks
iv also got a bulb out in my mileage counter i can just about see it
il fix it after mot i dont want to take steering wheel of incase i make a balls up lol
and one more prob guys when i lock my car the petrol flap can still be opened the wee latch dosent seem to work
putting a locking fuel cap on it
SilverSaloon
w124/1994/om606
it wont fail the mot because of the SRS light.
check the connectors under BOTH front seats and also check that the wires that go into the buckles are not broke.
Alex Crow
Super Suffolk
if it stays on for 1min+ then goes out AND STAYS OUT until journey`s end, it needs the fault codes erasing. someone probably changed a dash bulb and turned the ignition on with the dash out.
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
thanks
Steering wheel does,nt need removing to remove the instrument cluster, it can be done with the wheel still in place.
PJayUK
Had this on my ML, looks to be a connector that goes into the ECU block under the passenger seat.
