The SRS warning light on my 2003 (52 plate) C180 kompressor estate will not go out. My usual garage has tried two lots of diagnostics equipment to clear the fault but neither will talk to the control module. The suggestion is either a blown fuse, disconnected wire or SRS module has blown. Has anyone else had this problem? Is there any easy fix? Is there an easy way to get at the fuse or control module? The module is in the centre consol / dash, not sure where the fuse is? Any ideas would be great!
