Starting 220d in the freezing weather
Westmead Hawk
CLS SB 220d AMG Line Premium 2016
Well, it's a red letter day. One week without the EML on. Hurrah. Let's hope I've not spoken too soon.
How do I tell if the battery needs replacing? The car is a little hesitant to start in cold weather when it's been left a day or three. Any recommendations? I've just spent a fortune at the dealership on MOT and NOX sensors so would like to avoid them until the service in the summer at least (much as I love their free drinks...)
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Best thing to buy is a smart charger. eBay £16 for a 8 amp version. Use it at times of little to no usage of the car.
Test the battery with a meter, if it reads much below 12.4v with engine off then it’s in need of charging/replacing.
Battery conditioners are great for cars not used regularly, connect them up and leave them on until you need to use the car again.
W
Westmead Hawk
Thank you :)
malcolm E53 AMG
You do need to be aware of battery condition if you do a lot of short journeys especially in the extreme weather we are experiencing at the moment. These cars are extremely power hungry, COMAND, air conditioning and heated seats consume copious amounts of power especially using COMAND when the engine is off. I generally give my cars a top-up charge with a CTECK charger every 3 months or so to keep the batteries in good condition if you have a voltmeter check the battery condition a healthy battery should be 12.6V if it drops to <12.4V it needs a charge. If the car has been in and out of the dealer lately and stood waiting for a repair that generally means it could do with a top-up charge.
W
Westmead Hawk
Good advice. I've booked the car in to get the battery condition checked. We avoid short journeys since it's diesel but sometimes life has other plans. I'll look into the CTECK charger.
Chrishazle
Nr Ashford, Kent
If you have power avilable, a battery conditioner is a life saver, I've used one for probably 20+ years on our sunny weekend or emergency use toy (that lives in a garage with power available), not only means the car starts first time every time but also seriously enhances battery life. When I sold the 968 coupe the battery was 10 years old and still going strong.
For the past couple of years I've used a Lidl £15 conditioner on the SLK, it's worked (touch wood) fine, not as versatile as a CTEK but less than 1/3rd the price. Previously I used a Swiss one that, when I bought it 25 years ago, was the only one with a vehicle manufacturer recommendation (for shame, BMW!!) which even then cost 3-4 times more than the Lidl one! It still works, so I keep it as backup now.
Cold weather affects start-up on our S204 C220, which lives on the driveway and gets little use these days. Initial turn-over is sluggish but car starts OK and battery is fairly new, but even after just a few miles run it starts fine.
Don't know if it will work on your CLS, but on my S204 with key at position 1 hold down steering wheel buttons Answer phone, Hang up phone and OK all at once for a few seconds and see if you get a menu, if yes click on the first menu item to see battery voltage and amps, start engine and drive away, you'll see what the alternator is doing until you press back or switch off.
W
Westmead Hawk
I will give this a go to see. Thank you - that sounds very useful if I can see the battery stats.
tpn
S204 OM651 2012, Daimler V8 250 X 3
Check to see if you have an AMG battery-you should have one.
AMG batteries cannot be properly charged unless you use a charger with the programme to charge AMG, as opposed to "flooded batteries".
AGM batteries are designed to require14.6v – 14.8v when charging, whereas standard lead acid batteries need 13.8v – 14.4v, hence this is what most onboard chargers are designed to deliver – not the 14.6v – 14.8v that AGM requires.
from Canbat: https://www.canbat.com/4-tips-charging-agm-batteries/
From Ccar: https://ccar-greenlink.org/agm-batt... battery charger,to expose to our technicians.
I use a Noco Genius. Great charger. Hope this helps.
From Ccar: https://ccar-greenlink.org/agm-batteries-never-use-conventional-chargers/#:~:text=Using a conventional battery charger,to expose to our technicians.
AGM batteries not to be confused with the sporty AMG batteries…;):cool::p
tpn
predictive text(why did it miss the others)-nearly as bad as start/stop, but none as bad as putting an ordinary charger on an AGM battery;):alien::geek:
W
Westmead Hawk
Bought a new battery after having it tested. Whole new world now - stop/start function working amongst other things. None of the advice wasted as will need a conditioner to keep it in good nick based on usage.
  • Like
Reactions: tpn
51315
Canterbury
W247 AMG B200 (2020), A160 (2009) CLK270 (2005) SL230 Pagoda (1964, long gone)
All very fine if you have mains power, driveway, garage. But what if the car has to live on the street? What then?
tpn
Then make sure your battery is an AGM and use a solar panel to keep it charged
Solar charger
onefortheroad
uk.
51315
Canterbury
Thanks onefortheroad, but can't quite see that lasting long stretched right across the road. Parking only t'other side on our street!
51315
Canterbury
So would an AA 4.8w solar charger work with an AGM battery (on 2020 B200)
It’s not a lot, however I used one the same on my smart and also VW Caravelle to keep the batteries topped up when street parked. It’s surprising how well they work with such a low output
