- Banned
- #1
Following on from this: http://forums.mercedesclub.org.uk/showthread.php?t=21304&highlight=stall
In a nutshell, starts runs for about 10 secs then stalls, then requires large amount of cranking to get going again.
I have replaced the engine side fuel lines (3) and this hasn't helped. Have been looking at the fuel flow (now that I can see through the new pipes), and need some info.
1. How "smooth" should the fuel flow be out of the filter tub? Should it be pure fuel, or is some turbulence/bubbles the norm?
2. It seems that by the time the fuel gets up to the top pipe en route to the injectors, all is well and it's nice smooth fuel, regardless of 1. above. Thus, it has to be a vacuum causing the flow to stop and cause the stalling - right?
3. If 2 above is correct, is it also correct to say that this can only be the result of air ingress somewhere the engine side of the filter pot reservoir?
Tks all
Tks all
