starting problem
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by vlthomas, Dec 9, 2012.
  1. vlthomas
    vlthomas New Member
    8
    Jan 23, 2011
    swansea south wales
    Your Mercedes:
    SLK/CLK
    hi i have c220 cdi on a 51plate 70k on clock,when i start the car first thing in the morning it starts for about 5secs the cuts out,i have to restart it for about 10/15sec with a bit of throttle then its starts?it then drines perfect is it because of the cold weather?any help,it has had a fuel filter change at 35k,
  2. mersum1es
    mersum1es Senior Member
    1,959
    229
    Sep 25, 2010
    Finland
    Your Mercedes:
    Air in the fuel system (diagnose would pinpoint if so). Probably cause one of these: O-rings of injector return lines, o-rings of other low pressure lines, o-rings of pressure sensor/regulator, injector internal leak, hp pump internal/external leak. Do a search, lotsa discussion in the forum...
  3. WG M-B
    WG M-B Senior Member Authorised Forum Supporter
    3,105
    6
    Dec 5, 2010
    North west london
    Your Mercedes:
    C63 Wagon in black
    Replacing the plastic fuel lines usually cures this
Share This Page
