Starting Problems-450 SLC
Africa450slc
Hi guys;
I have a 1979 450 SLC.
The cars starts ok when cold but takes about 7 seconds before the cold start valve supplies the fuel.When it starts it is not a smooth start ; the engine seems desperate to turn over.When it starts everything seems fine.
However when the engine has reached operating temperature during driving; it has difficulty starting if the car is switched off for about 15 minutes.If I switch off the car and restart immediately ; i have not problems starting it.The problem only seems to be if i leave it for about 15 min.It can take about 20 seconds of swinging before it will start.
I also noticed that the take off power is a little sluggish.
could it be timing related?
all suggestions and thoughts will be appreciated.
regards
collin
mattkh
England
A160 W168 1999 1.6
Are you in Uganda ?
Check the voltage drop at the cold start injector.
A
Africa450slc
starting problems-450SLC
Hi matt;
i am in south africa.why u ask ?
If i find out that there is a volatage drop; what should I look at ?
thanks for your reponse
regards
collin
Legoman
either that or the fuel pumps on its way out , low pressure would mean it takes time to restart after its left for a while
Tel: 020 8863 9233
