Steady driving vs Cruise control
Discussion in 'General Mercedes-Benz Related Discussion' started by SquabzZz, Dec 22, 2012.
  1. SquabzZz
    SquabzZz Senior Member
    87
    Oct 28, 2012
    Essex
    Your Mercedes:
    CLC 2008 (58) 180K SPORT
    Hey people I'm pretty sure that my steady driving on the motorway can achieve better mpg results than cruise control (at the same speed).. Or is that not even possible ?
    I find when I have cruise control active I'm constntly slowing the car down and speeding back up but when i have control of the throttle I anticipate the road better
    What's everyone else's view as this is my first merc and first car with cruise control
  2. EmilysDad
    EmilysDad Senior Member
    9,218
    2,744
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    ML350
    Just anticipate a little earlier & move lanes so you can leave cruise engaged. But you'e correct, a right foot tends to be more economical than cruise, but it's hard work without it once you're used to it. ;)
  3. television
    television Always remembered RIP
    164,074
    309
    Your Mercedes:
    Yes better without CC, you are on a motor way with a incline ahead, you can speed up a little to stop the car from changing down, you get over the crest and you can back off as the car will free wheel down the other side. You can see a hold up a mile down the road, you can back off,CC cannot, or in other words, you can see the situation ahead,CC cannot;)
  4. ernieh
    ernieh Senior Member
    1,484
    93
    Nov 20, 2006
    Scotland, East
    Your Mercedes:
    205 / 67 / C220 d
    I tend to use cruise a fair bit, provided the road is reasonably clear and not too busy. When it is in use, I normally knock it out using the stock if I need to slow, and rarely with the brakes. My view is that if you find that you are knocking it out with the brakes, that is too late and you've probably 'wasted' a bit of fuel; its all down to anticipation!
    As for 'steady' speed driving, there has been a lot of debate.....CC will try to maintain the set speed no matter what, even if it means a down change and in that scenario, it will use more fuel than if you are content to allow the car to find its own speed at a given throttle opening. So, if 70 is set on the level, you might only get 65 on an uphill m/w stretch, but 75 on a downhill stretch, unless you hold it at 70 in which case you will save fuel.....hopefully!
    I've never tried any experimentation - too many variables on the road these days to get any meaningfull results, but what I can say is that I can see between 48 and 54MPG driving around 70 on my motorway trips south.
    There might be others who have opinions on this, probably disagreeing with mine!
    Ernie
  5. Blobcat
    Blobcat Moderator
    24,073
    10,102
    Near Grange Moor (not Wakefield...)
    Your Mercedes:
    R171 SLK280 3.0, Land Rover 110 County SW
    Yed you can get better fuel economy without using cruise control, however I see the wear and tear on my right leg to be more important that the slight difference between using cruise and not.
    As per above anticipation makes a huge difference, you can knock the stalk away to take cruise off, you can also tap it down and knock off speed in 1mph increments.
    If it was all about fuel economy we'd be driving CDI Smart cars everywhere...
  6. dml
    dml Senior Member
    413
    May 31, 2012
    Your Mercedes:
    R230 SL500
    Don't forget about the speed limiter as well (push the cruise control stalk in to change the mode from CC to limit - at least that's how it works on mine).
    Not only does it serve as a handy "license retention device" around town but it means on long motorway journeys I can maintain control of the throttle but once up to speed I can sink my foot to the floor and maintain speed (similar to cruise control, be careful not to kick-down as that de-activates the limiter and you'll get a bit of a shock :D).
    I did use cruise control last night on a 2 hour journey back from London but I wasn't particularly comfortable with it.
  7. OP
    SquabzZz
    87
    Oct 28, 2012
    Essex
    Your Mercedes:
    I do like the device but I think without it I get better mpg
  8. Naraic
    Naraic Moderator
    10,328
    942
    Mar 4, 2010
    Your Mercedes:
    2005 CL500.
    You can get better mpg without it. But I wouldn't be without it...saves leg ache.
    It also allows more time to concentrate on other aspects of driving rather than speed maintenance...I try to see how far I can travel without having to cancel it...it can be fun...and keeps you on your toes.
  9. television
    164,074
    309
    Your Mercedes:
    My eyes are getting so bad now I use the distronic all the time, I can read my own number plate from 60ft but not anyone else's
  10. EmilysDad
    9,218
    2,744
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    ML350
    I drove to Edinburgh & back yesterday, 3hr 45 each way. I rarely touched the throttle when on the motorway, set to an indicated [STRIKE]80[/STRIKE] 70 mph and even saw 30mpg! :cool: :cool:
  11. st4
    st4 Banned
    8,624
    Apr 6, 2008
    Sunny Scotland
    Your Mercedes:
    Disqualified driver
    Try the speed tronic. It allows you to set a maximum speed (70mph tends to work well) and you can vary the speed upto the set speed as appropriate and move the pedal and your leg without exceeding the set speed. Kick down disables it and if your legs have to go somewhere they might as well as go on the pedals.
  12. MBDevotee
    MBDevotee Active Senior Members
    1,367
    Feb 24, 2009
    Yeovil
    Your Mercedes:
    53 270CDI CLK Avantguard + ML500 with LPG
    I never understand people who have cruise and don't use it!
    I use it everywhere -
    30 Limit - protects your licence, and if you need to cancel it a tiny touch on the brakes does it - plus it allows me to cover the brake - if a kiddie stepped out in the road the 1/2 a second that saves me might be the difference between hitting the child and stopping in time (or at least only be doing 2 or 3 mph instead of 20)
    50 / 60 roads - perfectly good for cruise....
    Motorways - perfect.
    Rules for cruise for me are - keep plenty of gap to car in front and read the road ahead and its a godsend
  13. OP
    SquabzZz
    87
    Oct 28, 2012
    Essex
    Your Mercedes:
    I do like using it don't get me wrong but I'm just trying to work out if its more economical than my right foot under the same speeds !!
    As of I see traffic ahead and slow down using cruise control then pick up the speed it drops gear to reach the speed Ect but if I was controlling the throttle I would slowly accelerate to my desired speed
  14. Mic
    Mic Senior Member
    4,271
    127
    Nov 12, 2009
    Oxfordshire
    Your Mercedes:
    cc for continental ''m/ways''.......limiter for specs.
    Mic
  15. television
    164,074
    309
    Your Mercedes:
    And the next time you buy a car, make sure it has distronic :D:D
  16. Remenham
    Remenham Senior Member
    133
    Jan 16, 2012
    Bolivia
    Your Mercedes:
    a140
    In parts of Oxford there is now a general 20 mph limit. Quite amusing occasionally to set cruise to 20 mph and get buses, taxis etc stacking behind you.
  17. Mic
    Mic Senior Member
    4,271
    127
    Nov 12, 2009
    Oxfordshire
    Your Mercedes:
    I haven't tried that.
    Mic
  18. television
    164,074
    309
    Your Mercedes:
    That happens to me when going through Axminster :D:D
  19. JEZ.S320L
    JEZ.S320L Active Senior Members
    2,804
    3
    Aug 18, 2007
    Costa Calida, Spain
    Your Mercedes:
    None of my 3 cars will allow CC to work, below 30mph. There again, there's nowhere here where 20mph cruising is possible, nor desired :p
  20. television
    164,074
    309
    Your Mercedes:
    Yes 15mph is a far safer speed :D
Share This Page
