steering wheel removal
ecol
Grimsby
how do I remove my steering wheel outer rim for replacement on 1995 e220
You need a 2" long 28 torx bit to remove the air bag, do not turn on ignition without it plugged in. the wheel is held on with a 10mm hex key, and this will be tight at 90Nm
SilverSaloon
w124/1994/om606
hi
its a Torx (T30) driver you need to remove the airbag. Try to get one that is a full screwdriver otherwise the bit gets stuck in the holes.
the large allan key you need can be helped with the use of a bar of some kind attached to it (i used a trolly jack handle).
make sure you (or an assistant) holds the steering wheel in place when you undo/tighten the main bolt - dont rely on the steering column lock.
disconnect the battery to be on the safe side. make sure you dont touch the ignition with the 'bag removed.
apply some thead-lock to the main bolt upon refit.
E
ecol
Grimsby
thanks gents for the quick replies
The only way that I could get mine off was with the garage airline wheel driver and a 10mm socket
SilverSaloon
w124/1994/om606
I've removed quite a few W124 ones and also my R107 SL. These all came off relatively easily.
The CLK one i removed (W208) was a nightmare to remove and I almost gave up
E
ecol
Grimsby
Having looked at the wheel itself there is 4 screws at the back of the wheel itself which looks like it holds the rim in place ..do I have to remove the wheel completely ,or can the rim be removed ?.The covering on the rim has split and worn with age
E
ecol
Grimsby
the 1st one looks similar Malcolm ,but there is a definate joint at the rear of each spoke with a screw in each as though it is a seperate part
There are no parts sold for the wheels(safety item)are you going to re cover it
E
ecol
Grimsby
I think I might re cover it Malcolm if thats the easy option ,as I shall be selling it shortly to upgrade
This is not an easy job as 2 way stretch vinyl is not sold, and only used in industry, one way stretch is too thick, you could re colour what you have
E
ecol
Grimsby
it has crumbled in a couple of places and split revealing the base ,I have put some black insulation tape around the top of the wheel as a temporary measure
SilverSaloon
w124/1994/om606
has it got an airbag? sounds like you may have an aftermarket wheel fitted.
this is what you should have as standard (just leather/plastic - not wood)
E
ecol
Grimsby
yes it does have an airbag...but one thing I recall is when I had a new back box fitted some years back was that the car was listed as built for Hongkong market,and aquiring the box took some days
E
ecol
Grimsby
thanks for the info gents and thanks Malcolm for the Alfords link I will pop along to our branch and have a look
