You need a 2" long 28 torx bit to remove the air bag, do not turn on ignition without it plugged in. the wheel is held on with a 10mm hex key, and this will be tight at 90Nm
Having looked at the wheel itself there is 4 screws at the back of the wheel itself which looks like it holds the rim in place ..do I have to remove the wheel completely ,or can the rim be removed ?.The covering on the rim has split and worn with age
it has crumbled in a couple of places and split revealing the base ,I have put some black insulation tape around the top of the wheel as a temporary measure
yes it does have an airbag...but one thing I recall is when I had a new back box fitted some years back was that the car was listed as built for Hongkong market,and aquiring the box took some days
GAD was founded in 2009 where we developed bespoke ECU Remapping software for motorsport clients, moving forward, we have extended to road vehicles for both performance and economy, contact GAD Tuninghttp://www.GADTuning.co.ukto discuss your requirements.
