Steering Whine on 2001 ML430
Rogus
Can anyone help with this, I have developed a whine on the power steering when the car is cold, it get noisier when you turn the wheel. Once the car has warmed up generally after about a few miles the noise goes. Any idea's of what this might be also where is the power steering fluid tank as nothing is mentioned in the handbook.
hakulmi
Steering whines
HI!
I have exactly same symptoms in my SL129. During next service I am planning to change fluids to power steering (They might be original ones from -92). It never whines when warmed up. I found this whining when temperature was below zero celsius. Any other Idea than replacing fluids? It is not the belt.
Thanks in advance
Mike
gordonavenue
New Registration
ml pas whine
Rogus + hakulmi
did you gentlemen ever resolve this problem?
my ml430's pas has just started whining when cold, and i was wondering what solutions worked for you two.
any help would be appreciated.
many thanks
GA
panason1c
Somerset, UK
There are known occasions where the '0' ring/gasket under the fluid reservoir can allow air ingress and cause a whine...........very easy to change the 0 ring....just a single central bolt inside the reservoir to remove.
